Go Back   Forums > Quadro IP-PBX Products > 'How Do I' Questions
Old 02-22-2007, 08:16 AM   #1
brennja
How do I change the Voice Mail codec used when sending a voice mail message as an attachment.
I tried different codecs under "Voice Mail Common Settings", but they were all received as ULAW codecs.
ULAW codec is not compatible when I try to play it on a Windows Mobile 5 device.
brennja is offline   Reply With Quote
Old 03-01-2007, 04:25 AM   #2
ghutton
While I do not Epygi's voice mail for a bunch of reasons I will not get into. I use Broadvoice as my VoIP provider and use thier voice mail along with this free service http://www.magikinfo.com/vm2wm/which converts audio into several optional codecs. I use MMS to my cell phone and it works very well.
Hope this helps.
-Glenn
ghutton is offline   Reply With Quote
Old 03-08-2007, 06:40 AM   #3
hiebpbx
Hi Ghutton,
I would like the list of the things you would like changed on the Epygi VM system. It is the only way we can have changes.
  1. I am frustrated with fighting with codecs. Where do i download them for my users for Media Player?
    Voicemail navigation. Its toocomplicated, and there is no FFWD or REWIND. i want to have it the same as our Mobility provider (if that requires me to customize it so be it).
    Want common voicemail for 5 extensions (many ext ringing) with simple retrieval >*0 then password from any of themultiple ext's
Curt
hiebpbx is offline   Reply With Quote
Old 04-12-2007, 07:00 AM   #4
davrays
davrays's Avatar
Well, thanks for suggestions.
But I never though somebody could have problems with PCMU: it is included by deafult almost everywhere. Thats why Quadro doesn't let to configure the codec of the "VM to email" - it is fixed to PCMU, and nobody else had a problem with that.
VM navigation has FWD and REWIND - you can go back and forth using "4" and "6" buttons. Or you mean navigation inside the single message?
davrays is offline   Reply With Quote
Old 04-12-2007, 07:02 AM   #5
davrays
davrays's Avatar
Anyway, we are working on some redesign of ourVM system. Not sure when it will be included.
Voice Mail Time Out pluft Troubleshooting and Problems 13 11-30-2007 03:30 AM
transfer to voice mail Sparxnet 'How Do I' Questions 2 04-21-2007 05:30 AM
Option to login to voice mail awhite Suggestions and Feedback 3 02-03-2007 08:25 AM
Listen to voice mail from my PC warren 'How Do I' Questions 0 09-26-2006 06:10 PM
Voice mail impact from power outage warren Tips and Tricks 0 09-26-2006 05:42 PM
