Go Back   Forums > Quadro IP-PBX Products > Troubleshooting and Problems
Old 03-24-2007, 10:51 AM   #1
karelvergaerde
Hi everyone,
I'm trying to upgrade the firmware of my Quadro 2x-box and I'm getting following error:
HTTP Error 413: you tried to upload a file that is too large for this system!
What can I do to successfully upgrade my device?
Thanks in advance!
karelvergaerde is offline   Reply With Quote
Old 04-12-2007, 03:54 AM   #2
davrays
davrays's Avatar
That is extremely strange. Did you check the size of the file you are uploading (it should be something between 15 and 25MB)?
What browser are you using, and are you sure you are using right page for FW upgrade: the "update.cgi"?
davrays is offline   Reply With Quote
Old 07-11-2007, 06:14 PM   #3
stakano
Was there a fix? I'm getting the exact same error!
I'm currently trying to upgrade from 2.3.30 to 2.4.34
stakano is offline   Reply With Quote
Old 07-11-2007, 08:45 PM   #4
AramK
Hi Stakano,it's not a problem, just your SW is quite old and there is specialsteps for firmware upgrade.I assume that your Quadro is 2x and I wonder how you managed tokeep that 3-year-old image on your Quadro.Also 2.3.30 software imageis not in announced image list, it wasn't public image, so could you please inform us from where you have purchaced that device ? Anyway, it's possible to upgrade yourQuadro in following way:
1. First you need to upgrade your device from 2.3.30 to 2.3.38 (the official one)
2. Then upgrade your device from 2.3.38 to 2.4.34.
AramK is offline   Reply With Quote
Old 07-11-2007, 09:10 PM   #5
stakano
Thanks. Where can I get that code from? Do you have somewhere that I can download that from?
I just purchased two units this week from Hello Direct. Seems like they've had them for a while.
Old 08-03-2007, 01:50 PM   #6
karelvergaerde
Please,
do not only give us instructions on how to resolve the issue but give us the location to the firmware because the only ones to be found online are (too) recent..
Stakano, did you succeed ?
Old 08-03-2007, 01:55 PM   #7
stakano
karelvergaerde: Contact me and I'll get you the files you need.
stakano_at_gmail
Old 08-05-2007, 09:52 PM   #8
AramK
For such cases please contactEpygi Technical Support. They'll give you clear instructions and exact location of needed files.
outbound calling error mheller Troubleshooting and Problems 3 11-29-2007 10:04 PM
E1 busy tone error afripayments Troubleshooting and Problems 1 11-10-2007 02:54 AM
NEW Firmware 4.1.0 jloeken Suggestions and Feedback 1 11-16-2006 12:37 PM
Error trying to update Quadro16Xi anestis Troubleshooting and Problems 1 09-09-2006 12:36 AM
VM Settings page causes unstable error. threebit Troubleshooting and Problems 1 09-07-2006 05:42 PM
